Ranger4219
Primary info:
1999 Ford Ranger Flareside/Splash std cab
Eng and Trans 2.5 with a 5speed and a/c
3/2 djm drop kit with shocks rear installed front not yet.
1996 factory ford cobra 17x8 rim with 245/45/17 tires rears installed not front.
Roush racing rear sway installed front not yet
New Ford Hangers installed
New leaf spring bushings installed and new nuts and bolt for leafs and hangers.
I will include pics this is a two fold question. I am new to this but not to trucks.
I installed the rear set up but it still seems to sit up higher then some of the 3/2 drop i have seen pics of even with stock wheels and tires.
Directions said to put leaf spring bolt in the furthest hole from bushing but it does not seems right
Lastly Clearance issues i currently have the front jack up to start on the front sprrings but when i put the wheel on for test fit it slides on the hub snug but the tire is about pinky finger width from upper control arm. So when i put the 1 inch aluminum spacer on it it pulls it away from the arm but the factory stud stick to far out should i wiz gun them down so that fit? I do not think i will have a problem with the center cap install there is a lot of room in that respect.
Thanks ahead of time for any light shed on this sine I know there is alot of lowriders ahead of me in here.
