Lower intake oil leak
B2Mann
Arizona
Ever since I got my B2 its had an oil leak on the front of the intake between the head banks underneath the thermostat housing. Not a horrible leak but it gets to be kind of an eyesore. (I like my engine to be clean, and so does the engine) Ive changed the intake gasket 3 times so far to try and cure it. Also used rtv to maybe seal it up, but no luck..... Any ideas of a fix for it?? Its a 2.9l
Nothing funny about it. All hooked up the correct way. Always had the leak there. Not alot, but it makes a mess after a while. I wonder if it could be coolant, but it doesnt overheat at all either..
Everything seems to sound just fine. Barely any ticking. Maybe ill replace the pcv valve just incase.
