you can probably tell i'm a bondo brain(bodyman) not an eletrician.i don't know a whole lot about electricalis your F250 a diesel? does it run two Batterys?
rickcdewitt- There is NO voltage drops, at all? When the alternators at Max charging output? theres NO Vd? thats interesting, actualy, a first. How did you perform your Charging system tests??? There needs to be a controled load on the system to get proper readings, and no max output test is done at idle, cuz no alternator puts out max amps @ idle.
what would your plan of attack be?diden't you say what the procedure for checking the regulator is,and could you elaborate for a paint huffin' fool like me?
maybe i should try swapping regulators?(i know-damn parts swappin')
