djunkie
- Feb 6, 2008
1990 Ranger 2.9L 2wd, 5spd. The other day It developed a low idle miss. At idle it'll miss then smooth out out when the engine is revved up. When driving its fine above 1500-2000 rpm's. When I come to a stop then take off again it'll miss till it gets above 1500rpm then it smooths out and runs perfect. Fuel pressure is good, Its got a new ignition module and fuel pressure regulator too. Also I put in new plugs/cap/rotor/wires. I pulled the codes and I got a 67, 66, and 41. I think the 66 came from when I pulled the intake tube off to squirt throttle body clean in the intake to clean some of the carbon build up. Also the IAC valve is less than a year old and I took it off today and cleaned it and still the same problem.
I disconnected the O2 sensor just for the heck of it and drove it. Seemed good for about 2 miles then the problem came back. That may be the reason for the code 41. Any ideas?
