Low Range Light
DeanMLFlame
Tumwater, WA
I do know i get 4wd but when i try the low range button the light doesn't come...Does this mean low range isn't working and how do i fix this problem:icon_confused:
Believe you have to be stopped with trans in park or neutral before you can engage low.
Dave
For 4wd low, you must be in 4x4 high and stopped and in nuetral before switching to 4x4 low. If you're doing that your light might be burnt out, mine is for my 4x4 high.
If you roll you window down and you are somewhere quiet you can hear the electric motor go "reeeeeeeeeehc" as it engages both for 4x4 and then again for 4x4 low.
You can also tell instantly by feel if you've gotten into low range when you start range. A 2.48:1 gear reduction is not subtle at all.
