Low Oil Pressure at HOT idle... use heavier oil?
i know oil additives are just a band aid but for a high mileage truck like yours lucas oil additive or something similar may be enough to fix the issue. Cant hurt to try.
Yep, idle RPMs too low likely adversely effects OilPump pressure & Alternator voltage outputs.
Have V6~4.0L~SOHC here not 4.0L~OHV, but FordOE PressureSensor\Switch is a NotoriousFailureItem no matter the engine.
Over last 20years with this 4.0L & stock oil pressure switch, immediately before an engine Oil+Filter change, gotten habit of
spraying a little CarbThrottleCleaner down Oil DipTube+Fill, then running Engine for 5~10min, then changing Oil+Filter;
believe this helps clear sludge buildup & makes OilPressureSwitch respond a little quicker,
Also switched from OE spec 5w30.Blended to 0w30.FullSyn in Spring & 0w20.FullSyn in Autumn;
believe this helps get oil flowing quicker during ColdStarts, specificly to the PressureSwitch & the notorious TimingTensioners.
View attachment 79061View attachment 79062
I'm not running the stock oil pressure switch setup... I'm running this instead:
Haven't touched it in the last week... been slammed at work. Will replace the IAC if 3rd party ones are a known issue.
