johnnymac09
- Oct 8, 2007
Hey Guys,
I have installed a new/used 2.9L in my truck and I can't get it to start. I have been working through a few problems and have got it to the point where when I first turn the key it will bump like it wants to start but won't. I have checked the fuel pressure at the fuel rail and with KOEO I only get 10-15PSI, according to the Haynes manual it should be 40PSI. I have replaced the FPR, Fuel relay and fuel filter. I can hear the fuel pump come on when I turn the key. The truck is an 89, so it only has the one fuel pump in the tank. What are the chances the pump could be only partially working? Is there a way to test it to know for sure it is the problem? The new pump is expensive and I don't mind paying for it if it fixes the problem but don't want to waste money.
Thanks
Thanks
