9miller
- May 30, 2015
Hello all, I have been coming to this forum since I got my ranger in November and you guys have some great information, has helped me many times!
Now I am having a problem I can't find an answer for, my fuel pressure is at 12-14 psi at idle and running really rough.
KOEO is at 22 psi.
remove vacuum line on FPR and it jumps 8-10 psi At idle.
haynes book says 35-45 psi KOEO, 25-35 KOER.
Voltage to pump is 13.7v, ground ohms at 3.5 to frame.
changed out the filter, FPR, and the pump, had no changE to pressure. Just for the hell of it I replaced it all again since the pump and FPR were under warranty, both times I did the whole pump assembly.
I am not sure what else I can do, there is no leak as far as I can tell. What else could be effecting my fuel pressure?
this is on a 96 2.3l 5 speed. Any help at all is greatly appreciated.
9miller
KOEO is at 22 psi.
9miller
