jgt
- Jul 27, 2008
after a p0302 code, my mechanic friend said probable bad valve #2. after low reading in that cylinder only. He only did a compression test (not a leak down) and I've spent way too much money on this old truck and wonder if there's an additive we can try before tearing apart the engine.
new: wires, plugs, radiator,shocks,pcv, (2) vac hoses, intake manifold gaskets, oil change, fuel/air filter, brakes/rotors...$800 invested this month and can't spend any more.
All the spark plugs were dry and looked ok when we changed them. The truck ran perfectly fine until a couple weeks ago. starts up good, runs fair for about 10 minutes then rough and CEL flashing with P0302 code.
I read about ranger's "recessed valve" or possible sticky valve? Not a DIY home mechanic at this level, so I'd have to pay out to have this done. Truck has 146,000 miles and runs great otherwise and had timing belt/water pump, clutch, front end work done at 100,000. Seafoam or ?? thanks
