Low beams won't stay on
spottedsquirl
Hey everyone I have a 94 ranger. The low beams won't stay on. I have narrowed it down to the turn signal switch. Push the switch to high beam and they're on. Pull it back to low and no low beam. Pull in to flash high beam the highs come on. When I slowly release the flash the low beams come on and stay on until either I tap the switch or hit a bump just right on the road and out they go. Is there any way I can fix the switch or just replace it? Btw, I can keep them on as long as I apply slight holding pressure towards the high beam flash.
I'd either replace the switch, or wire in a foot switch, which will be a lot cheaper.
Thanks for the response. I've decided to go ahead and replace it. I studied several pics of the switch and came to the conclusion that it's gonna take more time than I have to attempt a repair but after I get the new one in I may turn the old switch into a project
