Loud ringing/ping on start up
Otto
Can't quite figure this one out. It's loudest on cold start and gets louder with acceleration. I know it's not the crank parts cause they're making noise too but very little. It almost sounds an electrically generated sound and not a knock or anything. Doesnt sound like it's coming from the alternator, valves not so sure. Have a listen:
http://www.youtube.com/watch?v=hQxp5oWxKrY
If I heard the right thing it sounds almost like an electrical whine, only worse. Maybe bearing going on the alternator? My 3.0 was loud when cold and it was a bad bearing. Especially when the alternator came under more load.
Doesn't sound like valve clatter. I'd have to say try to narrow down the belt driven accessories.
Thanks for the replies, I'm about 80% sure the power steering is good. Cause it does make noise when the wheel is turned all the way to one side so I'm sure that's good.
A loose bearing was definatly my second guess. I have a new tranny solenoid (B) put it tommorow, I'm hoping it's this as the sound is loudest at the bottom of the engine.
