cyborgv1
I've noticed a severe loss of acceleration up to 25 miles per hour, with noticeable vibrations. The vibrations are also present at about 50 mph. Mid range acceleration seems to be fine, but getting above 60 is challenging as the engine seems to get stuck at 3000 rpm. On hills the engine holds 3000 rpm's but loses speed. The engine appears to be running fine with no abnormal sounds when revving up to 4000 rpm in neutral. First noticed the problem half way through a 700 mile trip recently when I stopped for the night i a snow storm. I have slightly oversized tires. I also replaced the distribution cap, rotor, and the tfi-iv ignition module to correct a problem where the engine would stall (even at high speeds) when hot, and would fail to start until it cools down. Plugs look clean and cables were replaced not too long ago. Transmission fluid looks good. Engine oil was recently replaced and looks good as well
Engine has about 170000 miles
Automatic transmission rebuild less than 50000 miles ago
Will post engine codes when I get them read.
Thanks in advance for the help.
