MFerioli
- Jul 11, 2008
- Age
- 46
I'm showing a lower or maybe zero alternator output when I'm running in the higher rpm range. The battery gauge shows a definitive drop and the lights dim. It seems to happen when accelerating through the gears and also when at highway speeds and in 4th. I also have a squeal that shows up when its raining or just moist out. I checked to see if the belt was really loose, but seemed ok. Is there a bolt on voltage regulator on this truck? Could that even be the problem? Thanks for any thoughts.
Mike
2000 3.0 xlt Ranger
Mike
2000 3.0 xlt Ranger
