Sdude2008
- Sep 11, 2007
- Farmington CT
- 3.0 V6
- Tire Size
- 31x10.5x15
1988 ext cab 2.9 with 154k. I guess I pretty much know the answer but I thought someone might give me a new angle to look at my problem. I seem to be losing coolant at a steady rate. I first noticed the coolant level was down several months ago. I was topping it off about every couple weeks at first. I checked for leaks and found some fluid leaking down near the radiator drain plug. I also noticed when I opened the plug nothing would come out. I replaced the radiator. Now I am topping it off every day, it is about two inches down after about two hours of driving. I again checked for leaks and found some fluid dripping from the engine side of the lower rad hose. I tightened the hose and no more drip. Still the fluid level is down every day. This told me what i didn't want to know. To check the oil for water... I drained the oil and no sign of milkshake... However when I pull the filler cap I do see slight traces, like droplets of light brown goop. I don't see any evidence in the radiator itself... Also I checked all hoses while hot and all are warm to touch except the lower hose which is cold... So do I have some kind of blockage? Intake leak? WTF? I need this fixed can't be refilling rad daily... Thanks for any suggestions.
