- Feb 11, 2013
- Automatic
OK--went into tech library --printed out work sheet for TFI. everything looked good --BUT-- the spout reading from the harness--cranking is high at 10.6 volts --go to the coil and it does flicker. Did not go into the computer to pin 56 as I'm totally lost when I opened the kick panel. Is there a tech write up on how that is done?? Also when I check the negative coil side for flicker it's a bright quick flicker not faint. Am I still looking at the TFI ?? I just bought one but don't want to ruin it. I am going to replace the coil tomorrow. This thing ran great before I pulled and rebuilt the engine.
Also what fuel pressure should I have at idle. I'm getting 36lbs with vacuum pulled but with vac on it goes down as rpm's go up--is that the way it works??
What sensors regulate the idle?? the ICA idles it up when cold but after it warms it lopes bad enough to stall.
Been all thru these forums but can't locate the answers I need.
