Looking for some info.
Viper4600
North Carolina
So, I have two Rangers right now. One is a 2009 with an extended cab and four wheel drive. Unfortunately, it was in a wreck in 2010. It rolled so the body is pretty much screwed (the roof and bed are completely gone). The up-side is that since it went over on it's side and there was no front end collision the frame, engine, and all are fine and, besides sitting for a year, basically new.
The other is a 2000 with a regular cab and a 7 foot bed. It has about 187,000 miles and will most likely need a new transmission soon. The body is in relatively good condition (it exists and isn't too beat up). Me and a couple friends have decided to try and combine these two in to one truck, if possible. We aren't sure if it would be better to swap the engine and anything worth saving from the 2009 into the 2000, or to take the body from the 2000 frame and fit it to the '09. Any thoughts?
give us some more info, ie engine/trans/2wd or 4wd etc..
is the 09 frame good?
if i remeber, the frames from ex cabs are a couple inches shorter than longbed single cabs, atleast thats what im told..
a few pictures can also be helpful.
im thinking swap the whole 09 power train into the 00 but not 100% sure on it.
2009 is 4.0L V6 4wd, and yes, the frame is good.
The 2000 is a 3.0L V6 2wd. Both have automatic transmissions.
I'll get some pictures on here soon
if the frames are the same, id swap the body. transmissions between the 3.0 and the 4.0 are different. mabey you have to make a flat bed for it due to the frame lengths..
EDIT: Ok... frames are different lengths.. http://www.therangerstation.com/tech_library/Wheelbases.html
well, id go measure the 4 cab bolts in the single cab ranger and compare it to the ex cab ranger. if its the same, you got a cab and mabey a modified bed..
if not, swap out the running gear...
