Metal Man
OK guys lost here. I have a 93 ranger 4x4 4.0 Auto. I have a weird issue with my little truck.
This started in the spring. My truck runs really rough at a certain temp (outside temp) I been driving the truck since last spring and its not always done this.
When the outside temp is in the 50ish to 70ish range is when i have the problem. On days in this temp range the truck starts fine.After its ran for about 30 seconds the idle will start dropping and the engine will pick up a random miss (sometimes the engine will die). This fit will last about 1 minute then level off and run fine. If you try to drive the truck during this fit its acts as if its super lean. You can ease along at a slow pace but if you try to give it any gas it just falls on its face till you let up on the gas pedal. Once the truck is warm,if you shut the engine off and start over its not as not as noticeable but still there( starts fine..30 seconds later runs rough....1 minute later all is fine.
On cold mornings i have no problems. Just get in it and go.
I work at a salvage yard so i have access to used parts to try if i need them.
So far i have changed the MAF,TPS,IAC both coolant sensors and air intake temp sensor. I've also replace the fuel pump and fuel regulator. Added new plugs,wires and air filter. Replaced the coil pack. Replace upper intake gaskets and checked all vacuum lines for leaks. I even went as far as swapping the intake and throttle body for another.
I have not tried another ECM. And i have not replace the O2 sensors yet. Cats were gone when i got the truck. And i do have an exhaust leak were the exhaust pipe hooks to the manifold. .When i changed the plugs they looked great. Nice tan color.
The truck does not give a check engine light during this fit. I do get a check engine light after about 5 minutes of drive time( truck is running good by this time). But its done this since I've had it, long before this new problem started.
I really don't know what to do. Looking for some help here.
