Wanted Looking For 7.5 inch Rear Axle Cover With Fill and Drain Plugs.
Grumpaw
Virginia
2.3 (4 Cylinder)
Stock
Total Drop
Stock
Stock 225/70/15
I don't count birthday's anymore...just happy to be looking down at the ground instead of looking up
For my 2009 Ranger with 7.5 rear axle...
Looking for an aftermarket cover with a fill and drain plug. Plenty of aftermarket covers out there, but trying to avoid high cost.
Dosen't matter material, aluminum or steel. If any of you have done a swap and have one around, let me know.
Grumpaw
You can add these drain plugs pretty easy. I had to add a fill plug to mine because the actual fill plug was stripped/seized. It would be a lot cheaper considering you can get a new cover for around $20 and the $3-4 for bung plugs.
Yeah, I thought of that. Just trying to see if there's one out there before I start drilling.
New with plugs start at over $100 bucks. Don't need one that bad to spend that kind of $$$
With all the axle swaps you guys do, there has to be one lying around somewhere.
Grumpaw
