looking for 13-50 transfer case slip yoke info
1986fordranger
central VT
hi i have a borg worner1350 transfer case in a 1987 4x4 ranger parts truck that i am going to use and i think the transfer case has a slip yoke for the front driveshaft in the transfer case and what i am woundering is if theres a x number of '' of lift you can add before that slip yoke comes out of the case , also if i where to have custom drive shafts made would i have to use the slip yoke end on the new shaft ,thanks
Typically they're good up to 4-6" lift. I think binding of the u-joint yoke would occur before you'd run into any issue with it pulling out.
