- Aug 23, 2007
Only if you're planning on reving it past 4000 RPMs.
Sorry, but I just had to clear up a very common misconseption about how the SOHC is "more powerful" than the OHV. The only difference between the two 4L's is that the OHV revs to 4000 while the SOHC revs to 6000. The extra horsepower comes in that extra 2000 rpms. While that is useful when you're accelerating with the pedal on the floor, shifting at redline, that's not how most of us go around driving everyday, and is an especially bad idea when you have a trailer behind the truck. So in everyday driving and towing, there is no difference between the two 4L's.![]()
It would essentially produce more power through out the powerband... It doesn't sit at the same power level through the RPM's and then magicly jump 20 more when the truck hits 4000.
Say at 2000 rpm the OHV would produce like 120hp or something... the SOHC would probably be producing 123hp because the band is slightly higher then that of the OHV.
