longer pitman arm than necessary?
Boggin
hey guys, im soon going to order a set of 2" tuffcountry axle pivots from here
http://www.suspensionconnection.com/cgi-bin/suscon/20813.html
and ill probably be running 2" leveling coils with probably 1" or 1.5" spacers with the alignment bushings that come with those brackets, so would a pitman arm for the 4" lift be good? or is it possible for the pitman arm to be too long? i know i dont really need one but i wanna reduce all wear & tear, or does that make no sense?
thanks
It should be right about bang on perfect.
2" brackets + 2" drop pitman arm (the commonly-labeled-as-a-4" lift one) = :icon_thumby:
oh ok thanks, i only heard of the 4" ones and the "extreme" ones
Yeah the "extreme" one is actually the 4" one. You want just the regular one (an STX Highrider arm will work just as well).
