littlebrothers4wd
- Jan 11, 2010
- Automatic
im planing on building an explorer sport. im going to cut and turn the ttb i want to get about 6in of lift out of it but i've done some reading and it looks like the best way to go is cutting them at the lower ball joint but from what i read thats only good for about 4in of lift. so should i build a 2in drop brackets or should i get the other 2in by cutting them at the pivot. or is there enough adjustment in the alignment bushings.
im planning on getting a front end and building it then just bolting everything on if its possible
my plan is c&t the beams and brace
build longer radius arms with 3/4 hiems
ballistic fab 16in or 18in air shocks up front
flip the axle in the rear
33'' or 35''
33'' or 35''
