Long time reader in need of help.
84bluebronco2
Central New York
Have been reading this forum for awhile just to see what information I could dig up on a B2. Now I need some help with my B2.
Background:
On my way to class this morning the truck was acting the same as it did everyday. Came to a stop just before the problem and it took off fine. On the way up the street I pushed the clutch in and it stayed down on my way to third gear. I figured maybe it got stuck on the floor mat or something. I pulled it up and now it is frozen. I've never experienced this problem before and was hoping for some assistance. Thanks!
It has the 2.8L v6 carb engine and the 4spd manual if that is any help.
Did the clutch piston come out of the master cylinder? If so, you may have inserted in wrong so that it is not pushing against the actuator (or whatever it's called)...
You might also have a look at the floorboards around the clutch assembly to see if it has pushed through...
Now, the only thing that I don't know about your vehicle is whether they used the same type of clutch cylinder...if it has a throw bearing and rod then the linkage may be stuck...and that may need a bit of lubrication and a good screwdriver...not to mention the bushings may be worn...
