Long box vs transmission
Broo
Quebec
Back in 2010 when I was shopping for my truck, the only must-have feature if I chose a Ranger was the long bed. I didn't care about auto vs manual, 2WD vs 4x4 or 3.0 vs 4.0 as long as all those mechanicals worked right.
I ended up with a 2006 long bed, 2WD 3.0 automatic. Even though everything did and still work right, I find myself sometimes longing for a third pedal and a shifter. Now I'm not about to swap trannies as this is way beyond my limited mechanical knowledge, therefore it'll stay automatic. While looking at a 2006 tow rating chart I noticed there was no rating for a long bed with a MANUAL transmission, as if this combination did not exist, at least for 2006. Looking at my period brochure also seems to say the same.
Now that I think of it, while searching back then the very few long bed Rangers popping up were all automatics. Am I guessing wrong or was that really an impossible factory combination for the "late models" Rangers ?
No real reason why it would be limited to automatic unless Ford wanted it that way.
The transmissions are the same length so driveshafts wouldn't be an issue.
FWIW my '85 longbox is an automatic. :icon_twisted:
When I did the auto to manual trans swap in my 2000, the transmissions were different lengths. The auto trans was a couple of inches longer than the manual, so I had to get a longer driveshaft. I'm guessing Ford either didn't want to, or couldn't make a driveshaft with the necessary length for a manual/Longbed combo.
