lockers and gearing?
nyrangers
i just got my hands on a 2001 ford ranger edge, its got a ford 8.8 rear end and a dana 28 ifs front, anyone know if they make lockers and gearing for the front and rear? im looking for 4.56, 4.88, or 5.29 gearing..... any help would be greatly aprreciated.
http://www.trsfabandoffroad.com/products/menu_axle_components.htm
you're gonna have a standard rotation D35 up front. The D28 stopped production in 89' and somewhat lived on in "hybrid" axles from 93'-97'. After 98' all used a D35. But there is a difference between the 97' and earlier D35 used on TTB, which uses reverse cut gears, and the later D35 used with SLA suspensions, which are standard cut.
What size of tires are you running?
Yep, D35 IFS (which also uses a non-standard carrier, which limits your choice in lockers to a couple of drop-in style ones)
4.88 is deepest gears available.
