Locked up
Dangerrangers
Ohio
94 and 04
Do it right the first time !!!!!!!!!!
Hope someone can help on this one. Figured it out¡¡!!!!! M (edit) ¡ I m going to use a shorter belt
if the compressor is locked up just remove the clutch disk, its independent of the pulley/bearing assembly.
if the pulley/bearing is whats locked, time for removal or replacement. don't have to remove the compressor to replace the pulley, its held on the front extension by a big clip.
I want it out of my way ,no need for it . I'll use a belt for one without air . Thanks
You could unplug the wire harness and leave it in place if the pulley hasn't seized.
Sent from my XT1064 using Tapatalk
Please read my last post ,I want it gone . I don't want air in my wheeler !
