Location of PCM power Relay on 94 4x4 4.0
RobinHood
Henderson, NV
Without any rhyme or reason, my truck will decide it does not want to start. As you can imagine, this happens at the most inconvenient times.
l have done my research on the board and feel that it is exaclty what is described in this thread http://www.therangerstation.com/forums/showthread.php?t=18553&highlight=starter+relay
however, l cannot locate the relay. The stealership said they need the number from the part to look it up.
Any help would be great... thanks in advance.:icon_thumby:
Is it also known as the EEC power relay in the distribution box under the hood and are all four (AC WOT, FUEL PUMP, EEC & Fog Lights) of the relays interchangeable so if l bought four new ones l would be ok?
The AC and Fog light relays have different part numbers than the EEC and Fuel pump relays....
