'94 Ranger PCM/EEC location?
Kalwren
I've read through my Haynes manual and it says that it's under the dashboard, but it doesn't say WHERE it's at.
I've removed the kick panel on the drivers side and I wasn't able to locate the computer there.
I've been digging around under my dash and I see several "boxes" that it could be.
I've even looked behind the glove box.
I can't find the computer. Can someone tell me where it's located please? I believe I have a computer related problem and I'd like to replace it. The problem is, I don't know where it's located.
Does anyone know where it's at in the 1994 4.0L Ranger? If you have a picture of it, that would be a huge bonus. I'm not even sure the size of the box I'm looking for.
I tried searching on the site and didn't find exactly what I needed.
Thanks in advance!!
If its like my 99, its hiding under the cupholders under the center of the dashboard:
If it makes you feel better I didn't even know it was there until I took out my cupholders to clean them one day....
^ thats the RCM module for the airbags. As for the OP did you try looking under the passenger kick panel.
On a 94 drivers side under hood on firewall between brake booster and inner fender. two nuts hold plastic cover on with a bolt in center of wiring to hold to pcm! If I remember they are 10mm head nuts bottom nut is easiest to access with fender liner removed and using extension there is a oval hole allowing access to it. Hope this helps.
I didn't even know airbags had a computer of their own. I just assumed it was for the engine since that where I've seen it on my friend's Spirit and my dad's Toyota Terce- I mean, Nova...:icon_twisted:
Thank you sooo much for the information!
You are exactly 100% spot on! This is where I located the computer. I was surprised at how BIG it is.
I can't get that damn bottom bolt off of the plastic cover for the life of me. You stated to remove the inner fender. How do I take it out please?
