Little lift for the 94?
This is a little off topic but my door is Axle code 86.. on here it say it is a 7.5 but mine defiantly has the 8.8 under it?
if you want the 3.5 inch lift coils you need drop brackets for the beams and radius arms in which case you might as well get the rough country lift but just depends on if you want a higher lift or just enough to put in the tires you want.
you probably have the 7.5 unless it was swapped out before you.
has the 8.8 I had to change the cover and it a 8.8 cover ( flat sides, two U shapes at bottom)
Idk why it would have been swapped. It was a school truck for work around the school.
if i could i would switch to an 8.8 but i'm done putting money into my truck unless i got one for a steal
