Light switch?
my03ranger
SUBURBIA OF CHICAGO
I just got my lite tabs in from Underdog performance and installed them. Then I purchased some black KC daylighters. Doesnt look to hard until I thought about where Im going to install the switch! Where the hell am I goin to put this? Any Suggestions!
if you have a double DIN headunit space, and only have a single DIN installed you can put it in the extra space.
or if you have a center console you can cut out a little piece for your switch.
or you can tie it into another switch somewhere on your truck
orrr, just mount it on the dash
or you can cut into some of your trim pieces of the front of your dash
honestly, the options are endless...
Heres how I did mine, there should be room for two switches if thats what you need, I made sure incase I wanted to add another in the future
Hey cool man, Did you get that piece that goes around everything off to do that and how the hell? like the idea with the ashtray by the way!
Yea, there are two bolts under the radio, i think, that you have to unbolt, then pry the whole trim piece out. From there, you can run the wires down next to the radio on the drivers side, and under the dash, as there is a bit of an empty channel there.
