fredfx4
Want to know what you think about that one. I have a 3 inch pa on my 03 level II, i planned to put a skid plate underneat and everything is lower then the frame then i tought why not raise the powertrain 3 inch to clear the frame and do a full skid plate bolted under the frame. The support tab for the engine are perfectly placed for a 3 inch spacer to be put in and i could make a new transmission crossmember that would hold the skid at the same time has i also plan on removing the torsion bar for coilover in the front. It would also solve my trouble with my oem shifter bezel that doesnt fit anymore has both shifter would return to the right distance off the floor.
