Lifting Ranger
HBpencil
Hi I have a 93 ranger xl 4x4 and I bought it five months ago and I want to make it a better off raod truck... Im gunna put new tires on it, lockers and lift it. I want to fit 32x 10.5 or something around there under it. The back of the truck is 10 inches fender to tire and the front is 6 inches fender to tire and there are 27s on there right now. I think I just want to level it out to macth the back would that mean I need 4 inches of lift in the front!?!?!? and if i did that could I fit the tires I want on there!?!?!? Thanks for help
There should be a pic of my saagy front end
picture.php
ohh and what should I do to get the 4 inches.... suspension lift? new springs? spacers?
your probably gonna have to get you a lift to fit 32s suspension or body lift i would go with suspension james duff or skyjacker are the best one but they are a lil up there in price
You can fit 32s with leveling coils. Look at my build to see what I did. If you plan on wheeling it that's a different story. You prbably want more wheel travel so a lift kit would be in store
on the factory "Deer Print" rims, like you have, I had 32x11.50-15's on it.....
if ya look in the Tech Library you will see lots of good articles and How-to's to modify ya suspension for better performance.....
if ya on a budget, do the "washer" lift on the front to raise it 2".....
if ya truly want to increase the off-road performance of the suspension get extended radius arms from James Duff or Skyjacker along with their lift kit....
if you plan on getting a 4" lift ( or 6" ) then I would just get 33" tires instead of the 32" ones.....
l8r, John
Thanks guys this helped a lot Ill probly get the supension lift and possibly 33s cause Im sure Im gunna want to do a lot of wheelin in the future..
Thanks
Run skyjacker 4 inch class 2 suspention lift with 33"s get the kit with leafs for the rear and you will have a solid relyable truck..
