Lifting my 97
Lifting my 97
Lifting my 97
Next project, radius arm/tranny crossmember.
how hard was it to put that bottom drain plug in your diff cover? that is SICK, i like the idea of being able to drain/change fluid without pulling cover. thought about doing it on mine [ i can weld pretty decent ] i just need an easy size plug to work with, not sure if i should drill and tap cover or drill oversize hole and weld in a pipe coupler. :icon_confused:
I used a 1 1/8" ? hole saw to cut the hole in my drill press. That made it cake.
Just a note, the pipe coupler will weld kinda funny, may want to get 2 so you can practice welding it to steel.
I have been working on some stuff for the truck the last couple days. Pics can say it better than I.
Lifting my 97
Lifting my 97
Lifting my 97
Lifting my 97
Lifting my 97
Lifting my 97
yeah i thought about the coupler welding funny too. i'll check with local mascine shop. no worries though, once i pull my closed knuckle i'll have a spare cover to experiment with before hand as well. side note, 3 of your pics didn't show
What's taking so long? You done yet?
LOL
Good job!
new parts are looking good!
where the fudge is my diff cover?!
Dude, that really looks good......
You get the problem solved with the axle being too far forward?
