lifting my 94 explorer
jake122288
good old pleasantville, Iowa
i wanna swap the rear end setup to a spring over axle setup versus the axle over spring set up. how much lift will this give my rear end and what can/should i do to lift the front to level it out. it still has the stock setup up front?
It will give you about 5-6" of lift... You'd need drop brackets and springs to lift the front that much...
