lifting 2wd's
Status
Not open for further replies.
what is the name of the wheels you're running on your truck? are those just baja wheels?
old reply but i have basicly cragar soft 8's.
My truck as of yesterday.
I'm gonna bring this back up.
Has anybody used f150 springs and coils on a '98 + ranger?
Sent from my SGH-M919 using Tapatalk
Many people, jump on that search button and go on an adventure!
You don't think I have? Dude I spend most of my time on pirate..
I've been on just about every ranger forum I know of along with racedezert, most of what I'm finding is lift spindles or 1500-3k kits..
I was referring to the TRS search button, but the F-150 coils are very popular on the 80's broncos and rangers, but as for the 90's people usually use the coils for low budget pre runner builds.
Sure ya on a ttb its great, but on a 98+ I see lots about the spindles, some about control arms l and not too much about Just the springs..
And that's every forum I've searched so for...
It really depends on your suspension, either torsion bar or coils. You can use F-150 coils but you have to do a bit of modifications, usually they get you about 2 inches of lift. Spindles and shackles are the most common with the newer suspensions.
Roger, think I might try the f150 cois if I can't find a 3-5" set used or cheep..
lift
did mine different 3" body lift from summit $150, change out the 26" tires for 31's mounted on americans got a deal @ $400 like new set, total cost $550, and I got the tires you dont have listed in your cost, total lift 5 1/2" ,dont have the turn radius problem with the 3" spindles, and if you want to level it then do a spring hanger flip on the rear, I must be a bigger cheap skate than you:icon_thumby:
And see my problem is I can't stand a body lift, I won't tolerate on MY vehicle's..
If you're happy with it, then more power to ya but I can't do it.
I get off the boat on the 17th and I'll hit up the local yard and see what I can find, I've also been reading up on GM 1500 coils and 64" leafs...
Status
