Lifter Tic during cold start
ratdude747
Madison, IN
215/70R15
Lately I've been getting loud lifter tic during really cold starts. Once the motor has warmed up after a couple minutes it goes away. Doesn't happen all the time though (not tonight, anyway).
I'm currently running Pennzoil Platinum High Mileage 5w-30 oil. I have run 5w-20 and 0W-20 Pennzoil Platinum in the past with no issues. Should I switch back?
Likewise, is this likely a gummed up lifter (which could be fixed with seafoam before my next oil change?) or do I need to look into pulling the intake and replacing the lifters?
The engine has 140K on it; I've only had it the last 30K or so and I suspect the last owners didn't change the oil as much as they should have (based on what I saw when I had covers off it last fall).
Why did you switch to high mileage oil? Were you burning some? Pennzoil claims it will not burn as much.
The synthetic will run the innards cleaner, and flow better, so I doubt sludge. What are your start-up temps?
I run 0w-30 M1. If going back to thinner grade solves then I'd do that.
Have you ever done a used oil analysis (UOA) to see how the oil is performing?
Good oil filters have Backflow preventer, it is just a flap that prevents oil in the main passages from draining back into the filter when engine is off, this helps to get oil pressure back up faster when starting.
Gravity still drains oil from bearings and lifters.
Lifters have a spring inside to hold them expanded, until oil pressure takes over, you may have a lifter with a broken spring, so you get the valve train noise until oil pressure takes over.
I have a high mile 4.0l, 300k +
I use the Clear Flooded Engine software to crank the engine before starting each morning, that gets oil pumped back into bearings and lifters prior to starting engine.
Turn key ON
Press gas pedal to the floor and hold it down all the way
Crank engine, it will not start
Release gas pedal, it will now start
When computer sees "WOT"(wide open throttle) from TPS(throttle position sensor) and engine is at 0 RPMs, it starts the Clear Flooded Engine routine
Spark is ON, fuel injectors are OFF
So No Start
As soon as you release gas pedal injectors will start, even while cranking
The routine can also help diagnose engine problems
Also save you a couple of dollars buying a used car :)
"Hey this thing doesn't start first time?", lol.
Pretty much all fuel injection computers have this routine, not a Ford thing
FYI, if engine does start with gas pedal to the floor then you have a stretched throttle cable so no longer get WOT
Google: Ranger throttle cable mod
Or go here: http://www.therangerstation.com/Magazine/Summer06/throttlecablemod.htm
So you can get Full throttle back, really helps performance.
Because my motor has a few miles on it (160Kish?) and I figured it was the right thing to do.
Lately the temps have been 40F or below.
I've always wanted to do a used oil analysis but never got around to it.
I'm using motorcraft filters.
Didn't know this; that may explain something. Then again it's not consistent. I'd think that such would have the opposite effect, as when cold my pressures are higher, not lower. Hence why I'm thinking it's either a flow issue or a stuck issue.
Turn key ON
So No Start
Already did the throttle mod, I've never relied on clear flood mode to do that though. The only time I do such is right after an oil change (adding fresh oil), which I do by pulling the fuel pump relay and cranking until I see oil pressure.
That said, if it were a startup starvation issue wouldn't it clear in 10-30 seconds, not 1-4 minutes?
Just providing feedback here.
