RustedRanger
Intox it should be found in the Tech Library.
Some have had the media inside the fram oil filters collapse and from what they said in the threads they are more restrictive. Usually you can get the Motorcraft filters at places that have the Frams, WalMart has them and I got the last couple at Rural King,just remember the number of the filter cause some places don't have the books available...it's a FL-1A
thanks for elaborating on the pinging, RyanL. I reset the timing to 10 (with the spout connector removed), then retarded until pinging was minimal by ear. I checked the timing at that point and it was right at 0, about 10 with the spout connector plugged in. In another thread I found here, someone talks about removing the spout connector and setting the timing to 0 for all EFI Fords. I don't know about that, but it's ironic that I'm there by trial and error. I am running a 180 t-stat already. The pinging does seem to be a bit better at this point, however, it is still there. I will try looking into some of the sensors as you pointed out.
Does anyone know the location of the diagnostic link and the points to connect, to read the codes on a 90?
I think that it is supposed to be set at 10* BTDC with the engine warmed up and the spout disconnected (or at least that's the way which I always did it). At 0* I doubt that the vehicle will be very drivable.
Think of the spout as a vacuum advance line like on the older distributors (just an electronic version). Now I believe that the TFI module (it's mounted on the back of the distributor) controls the timing advance curve on our vehicles so maybe that is acting up and advancing it too much at certain RPMs. Just a suggestions since mine was running a little crappy and missing a little because of a flaky TFI. I noticed that my timing was jumping around a bit when I held the RPMs steady around 3K instead of holding steady at 20-something degrees or whatever. I am by no means telling you that your TFI is bad, just something else to check into which commonly fails on these vehicles. There's other things that you could check into like I said which can lead to a messed up air fuel ratio. I wish that I could hear the vehicle run. A lean running engine often gasps when you rev it while a rich running one kind of bogs down or sputters
- it is running pretty decent at 0*, so far the best compromise between power and pinging.
