Grunizzle
01/2013 OTOTM Winner
U.S. Military - Active
OTOTM Winner
Solid Axle Swap
Ok so my current susp. setup is completely stock in the front, and in the rear I have beltech 6400 shackles, stock springs, and I removed the factory blocks and installed 2wd u bolts to reduce axle wrap. I also have a 2'' body lift.
I want to get some extended radius arms on the front (I was planning on buying some from a forum member who makes them), and a lift big enough to clear 33-34'' X 10.50 tires. I was thinking of a duff lift but wasnt sure if 2.5'' would be enough or a skyjacker 4'' but I thought it might be a bit to tall (unless it settles a bit lower). Which lift provides the best flex? Would I need a drop pitman arm for either of them?
