87DangerRanger
how tall can u stack the washers for coil spacers on a stock 87 4x4 ranger suspension?
If you are gonna be cheap about it...buy real spacers and you will be safer, Bro. They are cheap and won't ever come loose on you. No magazine or TV 4x4 truck show has ever done a washer lift on anything and never will. The mags and TV shows all say to stay away from the idea of using washer for a lift. If you can....buy taller coil springs.
Actually wrong, the washer spacers are in fact safer than the poly ones because they don't break down, just make sure you weld a bead down one side and you are good.
Also you can do about 1.5in
