thanks for the info. Is it a pain to extend the brake lines?
just on the wallet.........100-130 bucks in that range.
to get a ideal look in the tech libary, the skyjacker kit instructions will be very very close to what you getting in to.
removing the rivits is the biggest pain in the ....... if you ask me.
torch, grinder, air chisel,center punch,hammer to remove rivits
2/3 jaw puller for the pitman arm
angle finder to set camber/caster
adj ecentric bushings to adjust camber/caster,get it close to get to a shop
tubing wrench for the brakelines
correct lug nut type for new rims.
1/2 inch drill drill bits...
and common hand tools sockets, wrenches etc.
good time to repack wheel bearing also, inspect ball joints etc.
extened radius arms?....might want to look in to limit straps or J hooks to keep the coils in the buckets.
over all its not rocket science installing a kit on a ranger, first time around and assuming your a fair wrench, expect a weekend start to fininsh
