Desert Jim
I have been a guest on TRS for years, and I'm finally going to start modifying my truck. I don't 'wheel like I used to, so I'm looking for function more than anything.
RC seems to have a good spring by their description, I figure a 4.0 Supercab spring would do the trick for my 2.9 regular cab.
The f250 shock towers would make it possible to get some good droop, but here is my problem... radius arms... The stockers bind up on a stock setup, and the store bought items I feel would give me too much caster. Not to mention the drop brackets.
In the 80's we used to weld some tubing and gusset up the stockers on the old f100-150's 2wd's cast arms, could I do something like that on my "new" stamped arms? How long would I need to make them? My "old" ranger 2wd had them back to the transmission cross-member, but it had hella wheel travel (combine that with the bent I beams, hella tire rub against said arms). I was thinking of splitting the difference. Has anyone built a set, or have a good idea of how to do it? I have some ideas in my head using thick wall DOM tubing, some square stock angle iron and plate. But proven is always better than an educated guess!
