birdmanslopy
- Oct 23, 2008
Could leveling coils and the leveling spacer work together for a poor mans suspension lift for the front of a 94 2wd ranger 4 cyl?
i know you can add the spacer under your factory existing coil but didnt know if that spacer can also be used under a level coil and if so would it still be able to be aligned.
the level coil and spacer would bring the front end up 3" if both could be combined.
i dont remember what was the max lift out of the front of a ranger before drop beams and everything but would 3 inches in the front work and could both coil and spacer be used?
