leveling coil did nothing
red_ranger93
ontario
the truck sits the same height as before when i put the leveling coil in
having stock shocks or the sway bar links wouldnt have anything to do with it would they:icon_idea:
just guessing, but are the shocks stretched as far as they will go--is the sway bar in a bind? Could they be limiting the coil travel:icon_confused:
well when i loosened the nut on top of the shock there was a fair a mount of downward pressure and i unhooked the sway bar link when the shock was fully tightened and loosened
whats your truck base, extra cab 4.0l, reg cab 2.3?..etc
is your truck toe in and its sucking the front end down when you roll forward?
possible chance you allready had levling springs?
What leveling coils did you get?(brand/part #)
taller coil springs should have made your front wheels look like this after you drove it \front of truck/.
Like the guys said, you may have already had aftermarket coils installed by the previous owner--compare the height of the old coils to the new coils (uninstalled)
ive bin partial owner of this truck since day one always has been bone stock i got the coils to finally level it out after tryin different things with shocks:icon_thumby: thanks for all the advice
