- Nov 6, 2012
- Age
- 31
- San Antonio, TX
- Automatic
went outside earlier to move my dads truck off the driveway which is on a slant, got in her, pushed the clutch in and started her. i expected her to roll backwards when i got off the brake, but she stood there like if the parking brake was still engaged, so i got out and had my dad press in the parking brake while i inspected the lines. nothing wrong, so burning the clutch i gave it the gas in reverse and the left tire skidded across the driveway while the right one pulled it along. so we blocked and jacked the rear end up and pulled the culprit tire off along with the drum, still wouldn't rotate freely by hand with the transmission in neutral. i prepared my self for the worse, an exploded differential. i unscrewed the diffs plug to drain the diffs fluids and the axle decided to start rotating freely again? i only got a little oil out and now its fine, what the hell caused this bizarre thing to happen.
pic is after we fixed it and placed it in the driveway like so, before it was turned around the other way
