Left Hand Side Valve Cover, 1995 4.0L V6 Splash
Airchime
Toronto
Hi all, I'm looking for a Left Hand Side (Driver's side) valve cover for a 1995 Ford Ranger 4.0L, V6, Splash.
F5TZ6582E
I'm having trouble finding this part.
All the dealerships/parts places that show them available (Lakeland, RockAuto, A1, Jackie Johnson) are actually not in stock, and Ford has discontinued them.
Any leads to an aftermarket, or if anyone happens to have this part to sell, I'd be interested.
Thanks!
yep, what mtnrgr said. I got a pair at the local Pull a Part. both sides of mine were rusted through....
AJ
And Aerostars, too, I believe. The Aerostar also had the 4.0 cologne engine (or was it a different 4.0?).
it did have the same 4.0... probably not the easiest vehicle to yank a valve cover off though, but if it is the only thing in the lot you do what you gotta do... and while you are yanking Aerostar parts, grab a set of the finned 10" brake drums for a quick swap upgrade to your Ranger's smooth 10" brakes (assuming you have the 10" brakes on your Ranger... If you already have finned drums, chances are it is the 9" version)
AJ
