Leaking reservoir?
FlyingFatass
So I got the P-brake/rear antilock light go off recently, so I knew i had low brake fluid. A few days after filling it up, I checked to see where the level was at. It seemed slightly lower than normal, and the piping below the reservoir was soaked in brake fluid. I guess either the reservoir is leaking, or the seals between it and the piping are bad. Anyone else have this problem? Also, should the reservoir be loose and easy to move around?
Bummer that you didn't get a response. The reservoir on my '91 Ranger does move around a bit if you move it side to side. But it was not leaking.
What was the resolution to your leak?
