rs1971
- May 10, 2009
- Automatic
Hi,
I'm having a bit of trouble with the clutch on my Ford Ranger and was hoping to get some input before I schlep it off to a mechanic as, unfortunately, I am completely clueless.
First the specs: 2003 Ford Ranger, 4L V6 4X4 manual transmission (M50D-R1HD, I believe), 60,000 miles.
Now the problem: Several weeks ago as I was leaving the house one morning, the clutch pedal sort of popped out when I disengaged it. This happened only a handful of times over the next week or so and I was optimistically hoping that it might have simply been getting stuck on the floor mat on it's way out.
Then one day a few weeks ago after having just parked at a grocery store, I happened to notice a small bit of black fluid leaking on the drivers side, very near the front of the vehicle. It occurred to me that this was probably related to the problem with the clutch but I sort of forgot about as I really wasn't having much trouble with it. Until yesterday that was when things all of the sudden got much worse.
As things stand now, the pedal doesn't really engage until about the last 1/2 or 1/3 of its range. Beyond that, it's essentially just loose and after I engage it, it only comes out part way. As I mentioned, I know next to nothing about any of this but having done a bit of reading this morning, the two possibilities for what I saw leaking are (1) transmission fluid or (2) hydraulic clutch fluid. Based on the symptoms and the location, is it possible to say which one? I'm assuming transmission fluid, only because that seems to be more common. Assuming it's transmission fluid, then I likely need to have either the master or slave cylinder replaced. Is that right? And if so, can anyone give me just a ballpark figure about what to expect on price?
Thanks in advance.
-rs1971
Thanks in advance.
-rs1971
