Marky48170
Ok, here's my problem my firewall is leaking on the drivers side from many different places like, steering column, clutch master, e brake, and a few others. I narrowed it down to the cowl vent. Just to let you know this is a 1988 Ranger that was setting for a couple of years and I think water stayed between the firewall from the cowl and rusted. My question is 1. Were is the drain for the cowl located on the drivers side ( maybe this is clogged ) 2. has anyone try to stop water from leaking in from the cowl ( firewall ) before and what did you use to stop it. I tried spray undercoating but that doesn't work well. I need something I can bush on. I looked @ rhino liner but @ $80.00 qt I don't know.
