Wrestle9902
I am about to convert my ifs to a solid axle. Should I have coil over springs or leafs in the front? I will probably get a EB44.
Ride like a "truck"=poor flex, if you want to prove how big your balls are because your truck rides like ass, that's fine I guess. I've ridden in stock solid axle yotas, they ride like a lawn tractor and flex about as good. Of course softer leafs will ride better and flex good but then it doesn't ride like a "truck".I'm a firm believer that a truck should ride like a truck.
I'm a firm believer that a truck should ride like a truck. If you want a cushy ride, then buy a Chevy. I think that leaves are easier to setup than coils, and a lot less expensive, you can go to a junkyard and buy 2 leaf packs for $50, then all you have to do is figure out the mounting points for the hangers, and figure out what you want to run for shackles, and pick a spot for shocks and your done (besides the steering linkages, but both are the same whether you run coils or leaves). With coils you have to figure out the mounting point for your radius arms, figure out your mounting points for a panhard, and figure out for the shocks. Unless you make your own radius arms, they can be expensive, I'd say leaves are cheapest and easiest to setup.
I ran my shackles in the front, so when it articulates it moves the axle forward rather then closer to the cab.
