Lower spring rate on rear leafs
92ranger4L
Grand Junction, CO
Not getting full travel up under normal circumstances (ie no load in bed) and the front hits bump stops while I have 2 inches of travel to go on rear when flexing out. Front coils already have a 1 inch spacer too and rear is stock. Imo it would be better to soften rear to allow fuller range of travel in rear before hitting front bump stops. I've considered 3 options: 1) remove the shortest leaf spring because on a flat surface, it's not engaged at all, but that may be too loose 2) cut shortest leaf spring down a few inches on a band saw, but that may cause the shortest leaf to put very high pressure on second leaf once it engages or 3) put a .5-1 inch spacer between 3rd and second leaf so that it doesnt add to the spring rate until deeper in the travel.
I'm definitely leaning option 3) but I want to see if anyone had any input
You referring to the overload leaf? (thick bottom leaf)
If so, is the leaf relatively flat? (only very slightly arched?) Flip it upside down, if so...
I do not recommend completely removing or modifying it though, as the rest of the leaves will likely fatigue right at the axle spring perch.
You probably already know, but your load-carrying capacity will be significantly diminished.
